The engine has two little cubes in each of the interior rear corners of the cab.
From the center of the cubes (which would make ideal seats for the engineer and the fireman) protrude a short piece of plastic. This prevents the crew from sitting on the cubes.
Does anyone know if this plastic is important to attach the cab to the frame....or if I find a way to remove it, I could cut the plastic off, and put the crew there. Any suggestions would be appreciated. Thank you.
