1 - 20 of 21 Posts
Well I bought the insulation on February 21st & here it is one month later and we finally finished this morning. (Sunday)
This was an extremely labor intensive job which would have been a lot easier if I had thought to do it before I started to build the layout. ;)
The first 2 photos show a before and after section. Note the difference in temperature with the job complete.
Nice job!! The sky behind those wind generators looks like Mars!!...now to do some painting! :laugh:
A nice increase in Temp, way to go Spence. It was 22 degrees this morning in Central Ohio, really ready for some 70 degree days.
Bill
Just looking at all of those seams and the cuts necessary to create many of them tired me out to the point of exhaustion because I know how much labor and time they represent.
Helluva a project--well done, Spence.
Well, that is a big milestone to reach. More fun now, and less shivering in the cold!!!
Pink looks adorable.:)(y)
Just in time for spring.😎
Good work!. Should make it more comfortable to operate during the cold.
Thanks for posting the temperature difference Spence. A delta of ten degrees makes things more comfortable. And less of your heating dollars are going out the wall. I can’t help wondering what the outside temp was on each of the days the photos were taken.
If you don’t want to paint the pink, here is another way to go for the backdrop. The paper isn’t terribly heavy and it may get some wrinkles during installation, but it’s a low cost way to have a background…unless you like sky blue pink.
I wouldn't mind a roll of that.
I would like to know if it has a matt finish or if it is glossy though.
Matt. It's about the same thickness as good wrapping paper. In fact, the bottom few feet are solid blue (no clouds). I only need the top few feet so I cut the bottom off and use it for wrapping paper.
539748
539749
I have a roll of that cloud paper sitting in the corner, that's a nice way to simply solve the problem.
Apply it like wall paper? If so, I'd use that stuff you apply first, not sure what it's called, but it allows wall paper to be easily removed.
On the Amazon link, they have different backgrounds. A few others may apply: "Mountains", "Summer Horizon", "Reclaimed Brick" and the "Wispy Clouds"
1 - 20 of 21 Posts
