7641 - 7660 of 8002 Posts
Plugger
Bill Fair here, I’ve just finished 52 years in the auction business and now am full time care giver for my mate. We have always had some kind of train setup going with kids coming in and out of participation depending on age and circumstances. Now I have the project to myself and it is my second top priority. My life MO is to plunge in to what I am doing and learn as I go, errors are learning experiences, all events in life can be viewed as positive. To date I have committed every error found in ALL the YouTube lectures titled “Avoid These Beginners Mistakes”. Have discovered my greatest joy is freelance modeling of weathered industrial.
Current situation is a 27’x12’ DCC dogbone being rewired for two reverse loops. Today’s problem: Can I use a Y turnout and just drive the train through the switch regardless of point setting? On the first one attempted the little switcher stalled at the frog (too short? Wrong track element? [Walthers DCC friendly]). Would like the same arrange for the other mainline join using #6 turnout. Who to ask?
Attached are a couple photos for flavor. The process has taken so long one of the buildings has gone into foreclosure :). If photos don’t show here see membership profile. Thanks
To Plugger
Absolutely Awesome work. I love the weathered detailing - such
character and texture. You will find plenty of expert assistance here on the forum.
Tonino
New member
Hi all.
I'm older than most, 67, and new to model railroading. For my first project I want to suspend an American Flyer set from the kitchen ceiling. The layout will be above the kitchen cabinets.
I will be doing a lot of reading on the forum to get a better ideal of how best to do this.
Vince Vaccaro
Hi Vince
I'm 80 - but dang man, hanging from a ceiling is well above my pay grade but rest assured, someone out there on this forum knows something. Welcome aboard.
Tonino
Welcome aboard!
Hi all.
Vince Vaccaro
Vince;
Seventy-one years old, and still playing with trains here. You might consider building your suspended layout in some room other than the kitchen. Cooking usually means some grease in the air. Over time it builds up, which is one reason so many house fires start in the kitchen. The grease, and normal household dust, will get on the rails and also on the plywood, or clear plastic support under the track. It will form a layer of "gunk" which will interfere with power getting from the rails up into the locomotive. Over time it will also permeate the plywood, or coat the plastic, turning either into a serious fire hazard. Yes, it can be cleaned off the plastic and track, but not out of the plywood. Even for a "young whippersnapper" of only 67, cleaning track up near the ceiling, on a regular basis, will be quite a chore. Most suspended layouts are built in bedrooms or family rooms. Either might be a better choice.
There are several threads on this forum about suspended layouts. You can use the search function in the upper right corner, to find them.
good luck, have fun!
I strongly 2nd Traction Fan's recommendation. Not in the kitchen, especially up high. Airborne oil and grease particles collect up there via rising heat even with a vent hood over the cooking surface. Anything stored on top of kitchen cabinets has to come down for periodic cleanings. The particles coat everything and then airborne dust clings to it making it icky sticky worse. Think it through a little longer.
Tonino
Wye turnout/spring switch
Bill;
Regarding your "Y turnout" question;
On the prototype, what you're trying to do would use a "spring switch." The points would not be rigidly locked in place, but rather held by a spring. The locomotive's wheels would push the points into position, no matter which way the turnout was thrown. Bye the way, it wouldn't need to be a wye turnout, the same system could be used on any turnout.
Meanwhile, in the model world, we have other considerations.
1) Electricity needs to pass up from the rails into the locomotive.
2) Our cars are a whole lot lighter than real ones. If the points are set "the wrong way," those light cars are likely to derail.
3) If it's a small switcher approaching, how many of its few wheels pickup power?
4) Is the turnout's frog a metal, powered, one or is it unpowered?
5) Is the turnout a "current routing" type?
What you want to achieve has been done. One common system is to put a photocell, or other train sensor, on each of the tracks entering the wide end of the turnout. When the train approached it tripped the sensor of the track it was on. The sensor then operated the switch machine to align the points for the approaching train.
Actually duplicating a prototype "spring switch" in model form would require a very light spring. It would need to be light enough to not derail passing cars, but strong enough to reliably hold the points against a stock rail for either route. You would also need some means of selecting, and holding, a route when the train enters from the narrow end of the turnout. Good luck doing all that! :laugh:
I recommend this. Use a metal frog turnout with the metal frog powered. It should also be an "isolated frog" which is not electrically connected to any other rails. Then use sensors and a switch machine to move the points based on a train's route of approach.
The attached file "All about turnouts" explains things like "isolated frog" powered/live frogs", and "current routing turnout" along with a lot of other info on turnouts and switch machines.
View attachment All AboutTurnouts rev 4.pdf
Hello, My name is Stéphane (Steven), I live in the south of France, near the city of Toulouse and near the border with Spain. I work in the French railways but I am fascinated by the Spanish and American railways. Fortunately, Google Translate exists because I speak very little English. It's easier in Spanish and of course in French.
Thank you for accepting me on your forum,
Stephane.
Hi I'm Bill and I live in Calgary Alberta. I built my first layout (HO) in 1973-74 but unfortunately had to pack it away when I moved from Mississauga to Calgary 45 years ago. i've decided to see if i can get back into the hobby. First I need to unpack to find out if any of my bits and pieces are still useful or do I have a trunk load of antique junk!
While I'm figuring that out, i'll poke around to see just how far I am out of date. I may be crazy to get back into the hobby, mostly because it takes time to design, build and landscape a layout. At 77 I'm not sure how much time I have left to play, but I figure it ain't over till the fat lady sings!
Cheers
Bill
Welcome aboard!
Stephane.
Stephane;
Welcome to the forum! We are a large, international, group of model railroaders. Our members have experience levels ranging from zero, up to multiple decades. All who like model trains are welcome here.
Do you have a model railroad now? If so can you tell us a little bit about it? What scale do you use? How much space do you have for your layout? Is it based on a French railway like SNCF, or a Spanish railway, or an American railroad?
If you don't have a model railroad now, do you plan to build one?
If you have any questions for us, feel free to ask.
Welcome aboard!
Cheers
Bill
Bill;
Welcome to the forum! Don't worry about your age, and whether or not you will be able to "finish" your railroad before that fat lady starts warming up! :laugh:
We have members in their 80s. I'm 71 myself, and their are plenty of old timers around this forum. Besides who cares if you finish or not, as long as you have fun along the way? :D Remember the old joke about an older man getting a lengthy prison sentence? He says, "But your honor, I'm too old to serve that long a sentence." The judge replies, "That's alright, Just do the best you can." :smilie_auslachen:
Yes, model railroading has changed a lot in the last 45 years! New locomotives run smoother, and are more detailed, than older ones. That detailing is true of the cars too. The new control system, DCC, has revolutionized the way layouts are wired and trains are run. Scenery materials have improved a lot. The use of extruded foam insulation board as a layout/scenery base has also changed the way scenery is built. Fortunately all these changes have made building a layout easier, and to some degree, even faster. So there's hope for us yet, speaking as one old fart to another! ;)
I wrote the files below for people who are just starting out on their first layout, but they may be helpful to someone starting over too? Feel free to read em. or ignore em' as you see fit.
Again Welcome;
View attachment Model Railroad Terminology 3.pdf
View attachment Improving Atlas turnouts pdf version.pdf
Hello and thank you "Traction Fan".
-I practice the railway from morning to evening, at work at scale 1: 1, and at home on the scale H0.
-I have a layout along a wall of a room. It has been under construction for about two years.
-It is a layout of the Spanish Railways (RENFE). Most locomotives and wagons come from this country. I also have some material from my country (France). Finally, two years ago I had the chance to spend a week in New York and bought a Union Pacific locomotive and four wagons.
As I live near the Spanish border, I have the opportunity to go there very often. (Spend the day in Rosas or a weekend in Barcelona).
I am of Spanish origin myself.
One of the stations where I work
My layout
Have a good day.
Hello everyone. My name is Tom Frazier and I live south of Miami Florida.
All my life I've had a dream of having a nice N or HO scale layout.
My RR interest is in modern German railroads (more about that in a minute) but also narrow gauge logging RR in HO, S or O scale.
I grew up in Germany in the 60's, 70's to 1981 and took many rides on german trains. about 15 years ago I purchased some locos rolling stock and track thinking that I would build a layout. Unfortunately it never happened. I ended up selling some of my things a few years ago but held on to a couple of my German Electric Locomotives hoping that one day I will buld a layout.
Fast forward to today. Unfortunately I have some recent health issues and no medical insurance and I have to sell my two locomotives. I am also a very active in the RC Aircraft community and go by the same TommyT in RCGroups where I have also started selling some of my things.
I don't want to deal with Ebay because of the exorbitant fees but also the scam buyers. If you are interested have a look in the N scale for sale forum where I will post shortly.
I hope to still get into Narrow gauge at some point in my life but at this point I have to get my medical bills paid.
Thanks and kind regards.
Tom Frazier
