joed - the paper is from Michael's, in the open stock paper section. In original form, it is seagreen foil, about $1.99 per sheet. Can do many side of buildings with one 12x12 sheet.
I just spray it chrome and the begin the weather process.
THere are some before pics from a different thread here:
http://www.modeltrainforum.com/showthread.php?t=14772
Signs are applied to clapboard (wood) siding from LHS.
TJ - After sanding the backside of the signs, I seal the signs with matte finish sealer (like you'd use between layers when weather train cars). Just a lite mist and let it dry. Hasn't run yet.
FYI - took me too long to realize NOT to trim the signs until AFTER you have sanded them. This will allow for fresh, smooth edges, but signs will still appear faded / weathered.
Next, I layout where the sign will go, put some glue near the edges of this area (on the clapboard) and spread over whole area with a moisted brush (water). I use Aleene's Super Fast Dry Tacky - use sparingly.Doesn't need to support any weight, just adhere paper to wood.
Carefully place sign on the designated "landing zone" and cover with a plastic sandwich bag (careful - no wrinkles!). Starting from the center, and using a toothpick, I gently work out towards the edges, carefully embossing each row of clapboards. Some glue will be forced out of edge of sign. I dab this up with a cotton swab as I go.
Take a moment after complete each embossing to let glue set. Then do the whole sign with a little more pressure (again using the bag as a barrier to prevent tearing). Any glue that leaks this time will be dabbed along edge of sign to seal it down, especially in the corners.
Give it a shot. Provides great results. Let me know if you need clarification.:thumbsup:
~Kingred
