“There are two fatal errors that keep great projects from coming to life: Not finishing, Not starting.”
― Buddha Gautama, Founder of Buddhism
Started the build after lots of preliminary work.
First pic: The entrance to an unfinished back room of my families 92 year-old house. Untouched since we've owned it. I cleaned out 40 years of storage (garbage) and painted the floor and walls.
Lot's of non standard construction. Like the reclaimed flooring for walls. As can be seen, I cut 1' off the wall to the right of the "pallet" door (my creation) and moved it to the left of the door. That gives me 51" from the back (sky blue) wall to door frame, just enough for the layout. To my surprise, the grey wall's existing studs didn't touch the floor. They were suspended from the rafters! Fixed that.
The feed to the outlet - wires and BX armor cut flush. "I wonder if that's live?" I stripped it back and grabbed the armor and the cloth insulation of the white wire. BzzzZzzzzzzz ... yes the white wire is live - fixed that. This stuff is as old as the tinplate that will run here.
Second pic: Pre-cut and drilled lumber and OSB for two of the three tables that will comprise the layout. And then the framing assembled. The concrete floor in the main basement is level. Back here it's more like an ancient Roman road. I used a water level to mark heights around the walls. Legs will happen when I finalize the table height.
