Hi. I brought this question up on another train site, and didn't get any replys. Could be they just didn't know either, as this problem probably doesn't come up much.
I had to remove the truck on my prewar 2235W Tender, and in the process, had to grind away the rivet end of the pin the truck pivots on. This pin has a riveted end and a snapring end.
My question is, how do I obtain one of these? Anyone have a part number? I bought a PreWar coupler rebuilding kit off E-Bay, and it has all the stuff I need in it, except for that type of pin.
The kit does have pins, but they look like you would put them in from the bottom and then just slip on a snap ring. Where the rivet end would be, is a nailhead type of end. Also, I think the ones I got in the kit aren't long enough to go through the coupler, the truck, a thin washer; and the tender frame. The metal from the coupler is fairly thick.
Any help would be appreciated.
Jack
Jack
