So I've been "testing" my models, seeing what looks good, what operates well. Trying to figure out exactly what I want to accomplish.
Also picked up a second pair of Kato Es44ac's bringing the fleet to 4! Found some of the older ones available online so I've got road numbers #2801, #2825, #2814, and #2822. That gives me enough power to double head both sets of cars.
Some clarifications. The Kato couplers on the engines and Maxi cars are great, its the ones on the coalporters that don't work for coupling. They really need to be dropped into each other (as the directions show), not really good for switching operations. They will not go together by pushing the cars together, they have a shock absorber built into them, which works great when pushing a long string of cars, just not for switching.
I've been watching a lot of layout videos and doing a lot of driving for work, so I've gotten a fair share of railfanning in. That said, I'd like to be closer to the prototype.
So some things I'm going to change:
1) Minimize switches, extra cost, extra maintenance, same as the prototype. Eliminate all "fancy" switches, moved to
ALL #8 frogs.
2) Longer visible mainline run, I'd like to make use of some signals eventually. Having so much hidden doesn't really work for the visual appeal.
3) Double ended yard, the local yard is double ended with one side having a long yard lead. I'd also like the yard tracks to be able to handle a full length train, 76". This also mean I can do more staging on scene, and eliminates the need for hidden staging.
4) Passing siding, double track mains do not exist in my region. I'd like the challenge of using a passing siding rather than just run them around on their own tracks.
5) Hidden reverse loops, these look rather unprototypical for my region, but I like the idea of sending a train off layout then having it return flipped around. I'll probably double track the loops so that I can have a train staged in each loop while not blocking thru traffic.
So I've come up with the following...
The red portions with tunnels will lead to lower level reverse loops.
Let me know what you think, I'll probably adjust some of the spurs, but that's the location they will come off the main.
