Layout Update
Ok so here is the latest update to my layout, grid is 12". The space i have is about 25% of the garage but it was not readily apparent from the pic so I included a portion of the garage area so the layout location is easier to see.
I'll build this in phases starting with the inner loop, then the outer loop and finally the interchange/extension.
I tried to reduce the amount of track but didn't really succeed, so I'm looking for suggestions.
These are not set in stone but here are my thoughts on industries, suggestions are welcome (era mid-late 50's, loop = small/mid-size town, extension = rural area)
Industry-1: Oil & fuel depot/dealer or freight house(is this redundant with a team track?)
Industry-2: food processor/cannery or cement manufacturer
Industry-3: dairy/creamery or small mining
Industry-4: rural mill or co-op
A few questions..
1. The interchange has 2 tracks, my thought was A/D for the interchange. Is this overkill?
2. This layout runs counter-clockwise, staging on the extension would be for departing off layout or would i be able to run arriving as well? If arriving is possible should i have it arrive via the same route or try to connect at the top right of the oval with a wye?
3. Is the three line crossover section by the interchange and yard overly complex?
4. Should I remove the inner loop and attach spurs to the outer loop? 1 train continuously running(unattended) is required to keep my son happy so I can run operations, this is why having a longer continuous run and the lift-out was and still is attractive.
5. Where exactly does the yard lead here start? If it starts at 'A' then its about an inch short, if it starts at 'B' than its too long.
