1 - 15 of 15 Posts
Since I don't really have much room to dedicate to running G scale trains inside, I am thinking of making a 'around the walls' track in the basement front room, which is perfectly suited for it.
I just need to try and figure the best approach and of course not making a mess a the same time. I think the track could total more than 50 ft, which is pretty big! And where the door is, a drawbridge or something similar could be installed. Same thing for the south window.
What I like about the potential set up is that the trains will be chest-leve - so you can actually see them up close, as opposed to having them up in the corners of the ceiling, straining your neck to see them...
This idea has been trashed due to the renovation of the room I was going to use... The best I will be able to do is display the trains, but not actually operate them.
Bummer dude. :( I would have liked to see that. IMO it would be cool to have them above the door level. Just have a swiveling recliner to chill out in while checking them out.
Actually, the level you were planning on sounds much better. I have left places with my neck stuck in a cramp from others being set up to high. ouch
Too many doors and windows in the room... It would have dominated. Plus the room is not a regular shape, so that presented more challenges.
You need a very large room with 8-10ft ceilings for it to work properly.
Wow, for some reason windows and doors never crossed my mind :retard:
Here is layout on a wall that you will like.
Hello all,
I thought you would enjoy seeing what can be done with a surround the room wall layout. I videoed a long G Scale train circling the room and passing the sidings under the overhang. It is a cute addition to our room addition. The video is here: http://www.cleantrains.com/id52.htm The sidings are on a wire shelf to let the light from the 3 overhead lights shine through.
I hope you like the set up, tell me what you think!:)
Sincerely,
Forrest Skidmore
Hello all,
Sincerely,
Forrest Skidmore
Nice train room.:thumbsup:
Do you have enough engines pulling the train.:D
It looks like you can really make those crawl.:D
Two Rail, eat your heart out.:laugh:
Hi Ed
Yep, those engines crawl just fine when there's so many amps available to the motors. I upgraded my throttle to handle around 12 amps, and the low end is pretty massive. I put 8 LM317 voltage regulators in parallel with a 9th one in series to step down the control current for the potentiometer. A CPU heat sink/fan combo keeps the whole thing well ventilated when 8 or more locomotives are being controlled. You don't see a lot of big lash-ups in G Scale, but all these engines run well together as long as the lighter Aristo units are in front. The USA Trains units will pull the Aristos right off the tracks if a big train is behind them!!:) I am glad you enjoyed the video!
Forrest
Forrest,
Nice setup. Was the room designed with the trains in mind? I noticed that the train path along the wall "conveniently" just clears windows, heating vents, doorway tops, etc. Dumb luck, or a pre-planned pathway?
Hi TJ.
Well, I wish I could say I planned it that way, but I would be lying if I did. I did actually design the room, but the train idea came after it was built. "Dumb luck" is quite valuable here! I did 'see' the train path when I decided to add the track, and it was interesting to notice how all the windows and doors had the same top height.
Sincerely,
Forrest S.:)
Im glad I came across this video...I want G scale, but I have three dogs. It would be a waste of my $$$ to do it outside because they would just tear it up. I have been inspired...G scale room is underway!!!
1 - 15 of 15 Posts
