This is for general information, I came across an LED Light Strip that was run over by a car. The gentleman saved it for me, because he knows my weakness. Anyhow, the strip has 128 LEDs and is used as a portable light for under the hood repair. A few were broken so I investigated. These are 5mm bulbs.
The LEDs are in parrallel, 64 pairs with 32 pairs on a section. Each has a resistor a very small
surface mounted resistor. The handle contained a 7.2 Lithium battery. So what is the resistor? Well the resistor is 181 ohms I calculated it at 160. 7.2volt- 4 volts for two leds divided by .02 amps. The volmater told me 185 ohms. I would of used three volts for each LED and used an 80 ohm resistor, so there is a little play in these calculations.
