In the general discussion forum, I promised a part list for the flasher.
Check out the Led Flasher in the General Discussion Forum it preceeds this information.
The preceeding thread.
I have a newer strobe light thread.
I'm leaving the LED, wires, and circuit board to you.
I use a standard board cut down to size with a dremel wheel and bend the leads in the direction I want to go and use a jumper wire as necessary.
Don't forget the 9 volt battery and lead adapter.
For fun, you can use a breadboard to experiment without any soldering
For wire I use 22 guage solid.I sometimes strip the cover off the wire and use it on long exposed leads on LEDS and resistors when assembling a board.
555CN Timer IC 276-1723 (NOT to be confused with the CMOS timer)
10 uf capacitor 272-1025
1/2 watt resistors 220k 271-1132, 2.2k 271 1121, for 19 flashes per minute
100k 271-1311, 10k 271-1126 or 41 flashes per minute
With exact part numbers I don't have to get into electrical specifications of components. At times, that will confuse me.
I use an 8 pin IC socket 276-1995. That way, I can switch the IC for troubleshooting. I place the timer in the socket, after all the soldering has been done.
Ohh Yah, you will need to rig a switch. This is the draw back for a battery system. I haven't used them but a magnetic reed switch woud be nice.
Aside from model RR applications, the unit is portable. It could be used for a halloween costume. Not in the rain of course.
