1 - 9 of 9 Posts
If I use an old transformer, example 3V size and I cut the round plug off the end does it matter which side I hook the legs of the leds to?
If it does how do I determine on the wall wart which wire is positive and which is negative?
a multimeter is the easiest way ....
if you don't have one, a regular white led can be substituted, if it's right, it will light .. on a led the longer lead is positive
1 - 9 of 9 Posts
