1 - 11 of 11 Posts
Trying to better understand this process. All/any help much appreciated.
I have some LED lights I want to install on my layout they are 3mm and 5mm white I purchased from AllElectronics. They said they are 3 volt and 20ma.
My power supply I have is output 3V, 500ma 6 w.
1) How would I determine a resistor size with this info?
2) how many of these led's could I use with this supply?
Thanks!!
In order to use resistor current limiting, you need to have some headroom. You have an LED with an operating voltage in the 3.0-3.3 volt range, and a 3V power supply. You really want a DC supply around 5V or more to have some headroom to add the current limiting resistors. For 5V, the resistor would be 100 ohms.
What about LEDs that have voltage:12V~18V(1000 Ohm resistor in series),Forward current (typ/max): 20mA/30mA. I purchased about 50 of these LED's to use inside houses and such. I just would like to know how to figure out the power supply needed.
Thanks for you help!
Mike
I’ve found the LEDs are almost too bright with my power source (old phone charger, cut the end off and figure out which is negative/positive) so I use resistors and combinations of resistors (in series) to get the look I want.
Coblesan, try a 12 volt wall wart, if that's too bright for you then try a 9v wall wart, maybe even 5. At some voltage they will not light due to insufficient current, you know you went too low then. My control panel lights use a 12 volt wall wart and 1k resistors. The current draw is around .01 ma per led. So a 1 amp wall wart can power a 100 leds, I would use a 50% safety factor and only power 50 or so per wall wart.
1 - 11 of 11 Posts
