1 - 8 of 8 Posts
I have successfully use Micro Sol to remove lettering from Bachmann and other makers engines and cars. Does anyone know if it will work on a BLI engine lettering. Thanks.
It should, although if it messes up, the consequences are worse (way more expensive loco messed up)....
Well I tried to inclued the thread but couldn't so check my posts about Broadway Limited Decals and you can see what I did.
Hummmmm..Using the search at the top of the forum, I have looked for Broadway limited decals, and brakeman and lovin it with no results...can you offer a bit more direction? I do appreciate your help! Thank you.
Look under technical model train forum on page 11 at the bottom. Listed at Broadway Limited Decals, hopefully you will see it. Let me know.
Most model makers use paint not decals to put heralds, letters & numbers on them. But modelers do use decals to change those items.
1 - 8 of 8 Posts
