1 - 8 of 8 Posts
I have 3 Lionchief engines. A Milwaukee Road 810 steam engine, another steam engine, Daylight 1727, and UP Diesel. Neither steam engine will go through a Lionel O42 switch without stopping. The UP Diesel goes just fine, no problems. Looking at all 3 engines the only thing I see different is the spacing of the pick-up rollers. The steam engines rolls at closer apart than the Diesel. Is there any way to help correct this problem? Any help out there would be very thankful.
yes the pick up rollers are too close together. does the tender have a pick up roller? if so run a wire from the pick up on the engine to the pick up on the tender. if no pick up roller you will have to add one, and then run the wire.
happens all the time.
This.
If the tender has common Bettendorf type trucks it may be easier to replace the trucks with ones from another engine. Most post war tender trucks have a pickup roller. Use caboose trucks if yours have leaf springs. Usually you can find beat up tenders and cabooses at train shows selling for less than what a pickup roller will cost you from Lionel with shipping.
Pete
1 - 8 of 8 Posts
