Lionel 1033 Hook up
1 reading
15K views 7 replies 3 participants last post by  gunrunnerjohn
That wiring is incorrect. For one thing, if you wire it like that, the whistle control becomes a bell control as the DC offset to the tracks will be backwards! It won't bother post-war horn relays, but any modern locomotive with an electronic board to operate the whistle/horn will not function correctly.
554525
Yes, the U on most single output Lionel post-war transformers was the center rail. The U on most Lionel multiple output transformers, OTOH, is the outside rail.
My guess is after they established the convention of U being the center rail for early transformers, they then had the multiple output transformers and had to change the convention. It would be hard to have U go to multiple individual loops and control all of them independently! :D
Not sure how those other quotes got in, just ignore please
When you click Quote, they all queue up. If you are ready to quote messages and there are quotes not to be included, you just delete them from the quote prompt before you OK the "Insert Quotes" dialog.
Here's the quote that I've deliberately included a couple of extra quotes in. See the trash can icon, to remove the extra quotes, click that.
554542
Here's what I ended up with to actually insert into the message.
554543
