I ordered a 16 Ohm speaker from Lionel to correct an issue with my Legacy H10 sound system. The speaker I order was part # 691-1209-536. When you look at the picture on their web site it shows a single speaker yet what I received was two speakers connected by a harness with a mini-connector.
The speakers are marked 16 Ohm 2 w. I was told that they had to be used together otherwise they would in fact only be 8 Ohm and might possible damage the sound board.
Now the H10 is not designed to have twin speakers on a single speaker. Now another speaker I ordered was Part # 691-1209-536 which a 2 “ Fatboy speaker. I’m planing on using it if it will fit into the tender and be an exact replacement for the existing speaker. If you try to look up the part number it does not come up properly and you need to request ”see all” and then scan down to find it.
So, any ideas?
So, any ideas?
