Hello -- I bought a 736 off ebay and while it is cosmetically very nice, it has never run properly. It starts off fine but within maybe 30 seconds it begins to make a kind of grinding sound and shudders. Shortly after that, it stops. It will run backwards a few inches and stop again, then will run forward a few inches and stop. It basically locks up. I have opened it up and:1. removed old lubricant from worm gear area and re-lubed with automobile 5w30 oil; 2. Cleaned armature and replaced brushes; 3. lubricated all axles and moving parts, very carefully and with just a tiny bit of oil; 4. ordered shims for the engine and carefully put them into place and run the motor on a stand.
Despite all of the above, the problem continues. Finally, I have tried removing all of the drive rods and running the engine with just the rear set of wheels. Then it runs perfectly - no funny noises, no stalling, even when I put resistance on the driving wheels.
When the drive rods are put back, it starts the same thing. I have compared the position of the wheels and the placement of all the parts with a working 736 and everything is the same, except mine doesn't run.
I'm running out of ideas. Any thoughts on this? All help much appreciated!
Paul
Paul
