1 - 10 of 10 Posts
· Premium Member
According to Olsens Toys ...
100-25 rebuilt E-unit orig, arm up, long plastic wire, $37.10
100-25C rebuilt E-unit orig, arm up, short, $37.10
Often, the only difference between certain Lionel e-units was the length of wire that was soldered to them.
when i searched for a e unit for the 2055, they said it was a 100-25c on ebay. at least that's what i came up with, however i found that the 100-25c was also for the 675, when i searched for a e unit for the 675, they are 100-25 with no c. so i guess maybe they are the same?
Per a manual, it is the most common. It will fit over 15 engines. A different lever is normallly a different type (number). Rebuilding is not too bad it will cost less than half the price. Having an extra around is a good idea.
All e units look like this. With the little lever they are the 100-25. It is in more steam and diesel emgines than any other for postwar. Common meaning many.
The change the drum thread.
1 - 10 of 10 Posts
