1 - 16 of 16 Posts
So now that i have decided to go O scale for my layout, my question is how do I connect my lionel gateman track clip to the Ez Track?
You don't connect that 153C to the track, you need the Fastrack actuator.
If your track doesn't have pins, you have a problem, they're required to join the track sections. They're built into Fastrack, they shouldn't be missing.
The picture doesn't look exactly like Fastrack, that's probably the issue. What brand is that?
I'm gone now for the weekend. I'll check when I am back home but im pretty sure that they are not fast track
No I don't think it is Atlas either.
Well a picture of Fast track,
The only EZ track I see is for HO.
Thank you
I looked on the MTH site and it really doesn't tell you how to hook up the accessories.
Once we had a Super mod here named B&M (Boston & Maine), he knew all about MTH.
He still has not been here since 5/8/2011?:confused:
Nobody will tell what happened to him??????:confused:
Discussion Starter #14
Thanks but the gateman assembly works by using the weight of the train, the clip pictured in my first post will not attach to the gray bed which is why I figured to use the standard piece in my last post.
1 - 16 of 16 Posts
