1 - 3 of 3 Posts
Can not seem to get whistle smoke to work. The blowdown worked for a while and it has quit as will. Any thoughts?:(
The manual says I should be able to adjust the level but does not give the command?:confused:
Mine is doing the same thing. Use the master smoke adjustment, it should adjust the whistle and blow down as well but still did not fix the whistle smoke.
Some times my whistle works, some time the blow down works, most of the time neither.
Mine also has started to kicks out the brick breaker when It goes from one block to another, if they are on different bricks/circuits. Did not do that when I first got it. I am going to send mine to Lionel in the new year.:thumbsdown:
1 - 3 of 3 Posts
