The question came up about the Lionel Missile Launcher, so here's a couple shots inside. I decided to lube mine and clean the commutator, so it was apart.
The large solenoid on the left fires one missile at a time on command, you can also use the vertical lever to manually trigger them, that's how the PW model without command works.
The underside of the missile launch platform.
A couple of product specific electronic parts, the motherboard is no longer available, hope that's not something that craps out!
