1 - 4 of 4 Posts
I picked up a Lionel Type 4050 60-W transformer and the speed control when in the off position still has power. I have never worked on a transformer before, does anyone have a resource on how I might fix this problem. Other than not going to "off" the transformer does not hum or get hot -- it seems to operate just fine.
Thank you for any help
Walter
It may not be worthwhile to try to fix it. If you want to try, first step would be to pull the top off.
Is this your transformer? If so, you'll have to remove the binding posts, I believe the wiper is actually attached to the cover. I don't remember exactly how the top comes off, but there should be a couple of screws on the bottom.
That is my model
Once I look at the wiper what exactly do I do? Is it just misaligned?
Thank you for your reply!
Walter
1 - 4 of 4 Posts
