Hey everybody, awhile back I picked up a locomotive off ebay (I know, but it was cheap) in hopes of painting the shell and giving it to my son. At first the train worked on the track, then stutteringly, and now just the headlamp works. I took off the shell and I can tell that no matter what, the electrical motor would not spin. I was wondering if this was of a case of either cleaning/replacing the brushes on the motor or replacing the motor? As a follow up to that, if I have to replace the motor, should I got with a Kato HM-5 because of the double shaft configuration or something else?
Picture of the train and shell, appears to be baldwin sharknose, but the brand on the bottom reads "Roco made in Austria", I thought they just did european stuff?
Picture with the shell off, axles have been removed because I wanted to see if the fault was in the friction of turning the wheels. Also is a heavy coverweight like that normal?
Also was concerned with the ground wiring (goes from terminal to my thumb, is that where it should be, between the metal chassis and the motor?)
Sorry for all the questions, I am a newbie when it comes to this hobby.
TIA for all the advice
D. Sullivan
D. Sullivan
