201 - 220 of 273 Posts
Thanks guys. I'll go slow and try to model realistic/believable scenes.
Andy
I went back to your first post to see what time frame you were modeling because I figured you were going with the steam era from your forum name, (yes my deductive powers are astonishing). I only saw LIRR trains after 1957 and never saw a steam engine in service so I have no idea what Mineola looked like before the 60's. I guess the buildings are the same but the businesses would be different. I really enjoy this thread.
Excellent work!
This is the first structure I built for the layout. It's the Fairview Dairy from Atlas. I'm using it for Kurtz Ironworks. I used joint compound for the mortar joints, and gave everything a black wash.
Steamfan77;
That is a fine looking structure! You did an excellent job! I've found that sometimes the mortar lines can sort of overwhelm the brick color, especially if the mortar is white. I see, in the last photo, That you did some weathering with your black wash. That's often a good idea as it can tone down the brightness of white mortar lines. If you compare that photo to the top one, before the wash,you'll see what I mean. The white sort of jumps out at you. In any case, it's a very nice looking structure! Well done!
In the photo below you can see how further suppressing of the white mortar lines looks. I don't know if that's something you want to try or not. Since your structure already looks great, maybe you'd rather leave it as is.
Discussion Starter #218
Nice work Traction Fan! Can you describe your process? Another thing I do (but not on this structure) to dull the white is to mix the joint compound with a little flat black paint. When I applied it, the joint compound looked like a light gray. I only learned about that after I weathered this building.
Chalk weathering
Steamfan77;
Mixing black paint into the joint compound, and the black wash, are both good ideas. If I remember correctly, this was your first structure build? If so, it's even more remarkable that it looks so great.
I do almost all my weathering with chalks. Years ago, I bought a basic set of pastel chalks* from the art department at my local Walmart for $3. I'm still using that set, along with a set of gray & black chalks, and a set of earth tones that I bought from Micro-Mark.
I first airbrush the red brick color on and let it dry overnight.
For mortar lines I just drag a stick of chalk across the pre-painted brick surface. Then I wipe the brick faces clean with a dry paper towel. I do sometimes use a black wash, but it will usually remove any chalk it encounters, so I may need to do the chalk over, after a wash.
Much more often I skip the wash, or any other liquid weathering material. Instead I "paint" with chalk. This process is exactly the same as painting with that "old school" set of children's water colors, in a long black tin box, that you may have had as a kid.
I wet a small artist's paint brush in water, and stroke it along a stick of chalk. Then I paint the chalk onto the model. At first, not much color shows. As the chalk dries, the color appears. With practice you can do all sorts of effects with chalk. By the way, you may have read about modelers "sealing" weathering chalks with Dulcote. I don't do this, since the Dulcote erases nearly all the chalk effects. I find that the chalk stays on just fine without any "sealing",even on models that get handled, like freight cars.
Any mistakes I make can be erased with water. I just rub a wet towel over the part I want to erase.
A brick building, especially an old one, seldom has every single mortar line showing the same color, or sometimes at all. Weather, airborne dirt & dust, and time, tend to dull and /or change the color, and prominence, of mortar lines. If you look again at my N-scale model of Seattle Union Station , you'll see some areas where the mortar doesn't show much at all, and others where it's fairly clean white. Also some mortar usually gets on the faces of some bricks, and sometimes used bricks are recycled into a new structure. The lower left corner of the single storey mezzanine part of the station shows this effect.
Below are some more photos of the station. It's all scratchbuilt, except for the two longer exterior walls. They are kitbashed from two different DPM kits. This is the centerpiece model for my layout, so I went a little crazy on it. :laugh:
* If you decide to try weathering with chalks, be sure to get "PASTEL CHALKS", not plain "pastels." The latter "pastels" are like crayons, and not at all suitable for weathering.
Discussion Starter #220
Thank you for explaining your process Traction Fan. Your station is a gem! I have used Pan Pastels on several structures and different parts of the layout. They are great to work with. I’ll post some more pictures of my ironworks building.
Andy
