I started the design for this layout over five years ago. Originally we had a 12x24 room for the trains, but as the kids got bigger, we needed more room to spread out so the trains and "living room" swapped.
The current room is 9.5x11, originally with a doorway, window and a small hall leading to the front hall of the house. The hall was closed off, the carpet replaced with reclaimed laminate flooring and the walls repainted a somewhat neutral color. The layout is a hybrid box design cantilevered off the walls as we need to use the space for storage as well. Most of the lumber is either reclaimed from the old portable layout or leftovers from other house projects. I was happy I didnt have to buy a lot of new stuff to make this work. I wish I had taken more pics of the build process but it was moving so quickly for a while that I didnt even think about it until this week......
Attached is the AnyRail design I made years ago to fit this room. Because space is premium, I went with a multideck design. The Staging area creeps up a 2%-ish grade to the main level. Eventually there will be a train elevator to move things up the second level. It'll be about 6' long so enough to hold a few cars. The location is fictitious and so is the operation. It'll operate like a branch line with the staging area being a distant district yard/interchange somewhere. The small yard on the layout will be the "local" yard that services both levels. Not ideal but running it on TrainPlayer seems to be entertaining enough.
