1 - 4 of 4 Posts
Take a look at this beautiful work of art which just came out in the MTH Premier line! When I see something like this, I am reminded why I love this hobby so much...
Take a look at this video and all of the detail and precision in action - https://extranet.mth-railking.com/videos/see.asp?show=20ST13419v&size=big
Here is the MTH product page, so check out those pictures
- http://www.railking1gauge.com/detail.asp?item=20-3293-1
And here is just some more info about the product itself from the MTH news -
February 11, 2008 - While our Union Pacific 4-12-2 is not the first O Gauge model of this unique three-cylinder locomotive, we believe it is the best — boasting smoother performance and more detail than any previous brass or die-cast version. Separately-applied details include sanding pipes to all 12 drivers, air and steam pipes with valve handles, brake shoes on all drivers, accurate builder’s plate and superheater patent plate, opening cab roof vents, front mounted air brake pumps, and hinged cab deck plate to give the fireman access to the tender. Boiler walkway surfaces are embossed with safety tread.
Perhaps the most fascinating detail is the working Gresley valve gear on the pilot deck, a series of levers that uses the valve gear of the two outside cylinders to drive the valve gear of the inside third cylinder. The design for this valve gear was licensed by ALCo from Sir Nigel Gresley, designer of the Flying Scotsman and other three-cylinder British locomotives. Sir Nigel, however, tended to obscure his Gresley valve gear under a protective cover, while the UP exposed it for easy maintenance access — much to the enjoyment of railfans, who delighted in the sight of these massive levers rocking about madly when the engine was at speed.
The model’s sound system is set to a prototypically correct six chuffs (and six smoke puffs) per driver revolution. As with all Proto-Sound 2.0 steamers, however, the chuff rate on the 9000-series 4-12-2 can be set higher or lower using a DCSTM handheld controller, to adjust the sound to individual user preference. When operating with DCS, you can also use the handheld to limit the model’s top speed to a prototypical 55–60 scale miles per hour. Lighting on the models includes illuminated number boards, classification lights, firebox glow, cab interior light, and headlamp.
Behind the model’s cab rides a Vanderbilt tender just as richly detailed as the locomotive, and connected to the engine by a wireless drawbar. As with all Premier steam engines, there is a real coal load. Opening hatches conceal sound and smoke “volume” controls and a battery charging port. Marker lights and a backup light provide illumination. The six-wheel trucks feature safety chains, and a rerailing frog hangs from the tender side to aid the crew in the event of a minor derailment.
1 - 4 of 4 Posts
