Thanks T-Man
Thank you, you are very helpful.
On the color code bit the wire currently on it are all black so when i get around to do the job i will just snip the wire at the inside near the solder joint and add to it from there then use a little heat shrink. Mark the track end per your drawing then it should go 1,2,3,4, I,m enjoying this site already look like alot of good people here. Thanks to all Marvfly
