I drew up this layout plan in windows paint using a copy/paste of a lionel catalog and wanted to hear some feedback about how it might function. I know it's a rough sketch, but it should be close enough to go by for now.
Obviously it's an L-shaped layout, and we're going for a '50s/60s style' layout here, nothing real fancy and not phenomenally realistic. We're treating this as a toy train setup and not an accurate recreation or anything like that.
As you can see there are two independent rail lines plus a trolley line. To make things easier none of the track will be elevated, but instead I will probably build up some aspects of the platform around the track to give visual interest. The track is laid so that both lines have involvement on each side of the platform. The sidings will be doubled, two per line. I am planning on running two 80w transformers, one for the longer rail line, and one for the short line plus the reversing trolley. The buildings will be lit on a completely different circuit.
The only thing that I am hesitant on is the fact that there is no means of swapping from line to line, and I did that intentionally due to a post on another thread stating that the swtiches do not automatically isolate sections of track when off and I want to maintain independent control of the two lines through the two transformers. If there is an easy way to do this with stock fastrack sections, I will include it and save myself a siding.
What do you think?
Thanks in advance.
What do you think?
Thanks in advance.
