1 - 13 of 13 Posts
Hey all,
Just picked this up. Another trade:D
As you can see, it needs some TLC
The bottom shot. The first thing I noticed is that the plate and spring are missing, and the bottom plate of the motor is broken.
The rear trucks are also missing.
Other than that, another project:D
Keep you posted....
Cheers, Ian
update
Hey all,
Got the 1666 pulled apart.
It has an e unit and a smoke unit(?)
It is really dirty, and I'm not looking forward to pulling the wheels off:(
Body work comencing....
Cheers, Ian
· Premium Member
Ian,
Why do you need to pull the wheels off? To access and replace the bottom contact plate?
I haven't tried pulling drive wheels on anything on my end yet. Do you have a proper puller gizmo.
I'm also jealous ... my little loco fleet are all smokeless. Not a puff. Nada. :(
Nice track ya' got there, too ... is that brand new true O (not O27) ?
Cheers,
Discussion Starter · #7 ·
TJ,
No, its O27. It came with the Amtrak set I picked up a while back. Nice stuff.
Yup, I have to pull the wheels off to replace the broken bottom plate and give the motor a good cleaning:(
I don't have a puller, but T-Man suggested I pick one up, especially now with all the Marx locos I have.
It would probably pay for itself:cool:
· Premium Member
A couple of the locos that I've been working on have the drive rods riveted (or peened, really) to the studs on the drive wheels, just like your photo above. As I clean and fiddle with the motor, I like to stick it on a test track and run it a bit, to make sure everything is working. But those darn drive rods just get in the way. They either bounce all around, touch the rail and cause a short, or jam into a tie and try to flip the engine end-over-end.
I hate to drill or file off the "peen" and remove the drive rods just to test the motor, but what's one to do with the "floppy" drive rods in the process? I tried taping them up out of the way a bit (with enough slack so that the wheels can still turn), and also taped a pencil across the front of the motor, and then layed the drive rods on top of that. But neither "solution" really works that well.
Do you have any clever ideas as to what to do with the drive rods during motor tune ups?
· Premium Member
That's a clever idea. I wonder if I could make something generic enough that could be added to my (small) bag of tricks and use it on any motor that came along. It wouldn't have to be "pretty" in any way ... rather just something that could get taped to the front of the motor frame with some sort of holes in the side to keep the drive rods sorta in check during testing.
And then, I could file for patent protection, mass-produced them, make a fortune, and retire early. Yeah ... that's it ... THAT's what I'll do! :laugh:
Discussion Starter · #13 ·
update
Works been slow going with the weather getting nice and all, but its raining today...so,:laugh:
A couple of pics. Cosmetic work has been started
Not running yet, got some replacement/repair parts coming...keep you posted:thumbsup:
1 - 13 of 13 Posts
