I guess you like the thread.
The e unit bugged me so I went after it. I got three engines from that antique dealer two are 999. So to answer a question yes it is a 999 I can't remember which one. Probably the one that doesn't work.
The theory is true about the coil reversal since the armature is just set up for a ground. I think, way back that Lionel may have one engine of the same configuration back in the 40's one of the smaller engines maybe a Scout or even a prewar.
For time I just putter, as for pictures that is fast and easy. I try to keep my explanations simple.
The 999 is a 0-4-0 The NY tender should fit but I found another slope back that is the similiar to the 1615. I am not sure what goes with that one.
Jim, it matches the 999 what I can't tell you is that there may be more. The 999 has a drawbar attached to the frame. On second thought it matches my older no number engine. It does have a number I just don'r know what it is. I can tell from the rodes and the front crossbar where the rod tips rest.
I am guessing the engine is a
591 from the 40's that's the time period for the engine. I got it from a relative who had it as a child. That was the only piece to survive.
It may be time to get a Marx reference.
