All good ideas. I have just accepted it as a fact of life that where all four of my layouts have existed, in basements, but one was in a loft above an out-building garage, one is wisest to have some rudimentary climate control. With milled lumber, plywood (which is quite stable and doesn't respond as much to humidity variation), and water-activated scenery materials, I have kept a dehumidifier on 24/7 so that it cycles when the humidity goes outside the 48 and 66% extremes. This has worked well. For a $170 investment, you would be able to use pretty much anything you can find cheaply that would be engineering-wise rational and durable to use. Including OSB, particle-board, Masonite, hardboard, door-skin, lath, strapping, pallet scraps, and MDF....oh, and Homasote.
