1 - 11 of 11 Posts
So far in the O scale Forum I worked on Post items now as the box is nearing completion I have a chance to show you some Prewar trains.
Here I start off with a roof to a 1630 passenger car.
Discussion Starter #2 (Edited)
More cleaning
It does drag on for eight minutes but after many instances of describing it , now you can actually see it at work.
Not bad without a script :thumbsup:
The audio is better than expected you can hear my allergy at work.:(
T, I have had really good results from naval Jelly.
I like it because it brushes on, and hoses off. There are the rough ones that use the wire brush, but I just put the brass brush in the Drill and super-clean it.
Have you ever tried it?
If so, what would be the comparison to that compound, which does look good.
There was a broken tab that holds the relay so I glued it first the added some epoxy!!
On these older tenders I find the roller springs are normally shot.
Just add a new spring
The old and new
It is not difficult to do, Just lift the spring one turn at a time over the rivet. The opposite installing the new one, Just don't bend the spring.
It's his artistic signature. Wouldn't be a T-Man project without a little epoxy swoosh somewhere in the mix! ;)
Nice cleanup on the passenger cars, T ... clean, but "aged character" still there.
Discussion Starter #11 (Edited)
I am stuck on the compounds. On this job I paid attention to the roofs. I have used it for aluminum. Also it took only 15 minutes for one piece. Why wait for the jelly to work?
1 - 11 of 11 Posts
