1 - 5 of 5 Posts
I have a couple of these that are bleeding a volt or two with the throttle control at zero. Any ideas on how to fix the issue?
Also; I cannot see see exactly what type of screw heads are holding the case together. Looks to be to be security torx type. If so, anyone what size? #6, 8, 10?
TIA
Scott
A little search revealed very little. You could try contact cleaner on the throttle pots and replacing the caps (any bulging?). Most of the suggestions involved replacement with a newer unit! Especially if your not equipped to lift the legs of the caps to test them.
a similar problem was reported on another forum and said cleaning the boards with alcohol helped. i think he removed solder flux that collected dirt and became partially conductive
1 - 5 of 5 Posts
