1 - 6 of 6 Posts
Hello everyone!
This may be old stuff to some but I recently aquired the MTH DCS Commander system for my new MTH PS-2 engines running on old Lionel
tubular track with traditional switches. The system is great but my switches do not operate correctly. The lights light up and part of the switch activates but not bot sides? I must be missing something. I know AC and DC differences and such but I could use a solution as I have too much invested in the tubular track to go back! Do I need the AIU and TIU setup? Thanks
Brian
What switches 1122 or o22? The 022 you can power separately the 1122 will have to be disconnected from the track. That is the first thing I would try. Can you tell us what the MTH power/current is on the track? I know zip about MTH.
These are the current production AC switches 12080 and 12081 042 turn outs (some are K-line). Half of the switch works quck and easy but there seems to be stray voltage on the other side (other insulated rail) used for preventing derailments.
Thanks
Brian
Discussion Starter · #6 ·
I have the manual but as with Lionel they are very basic descriptons of the device. I must need to rectify the current so that it flows in only one direction for each insulated rail section on the switch. I was thinking someone must have done something to get this most common switch machine to work on DC. I'll have to open one up an see how to proceed.
Brian
1 - 6 of 6 Posts
