1 - 10 of 10 Posts
Hello train buffs
Anyone understand the instruction for the wiring of the MTH gas station or
the MTH speedy car was...?
The problem I have is trying to understand MTH instructions.
Here goes You have terminal A B C D E
A_ red wire to terminal (+), black wire to activation switch
B_ black wire to terminal (-)
C_ black wire to activation source
D_ red wire to terminal (+)
E_ black wire to terminal (-)
I don't understand hooking A with red wire and black wire. I do understand
D and E operates the building light
red pos from D to terminal
black neg. to terminal
Thanks HELP
PoPDan
Big TIme Edit
Thanks to B&M for finding the manual I couldn't.:appl:
It helps to know where abcde are located.
Anthing more and I will need to see the directions by link or copy.( I just knew it)
Discussion Starter · #8 ·
Thank you Mr. T Man
Problem was just did not seem correct take terminal and connect red and black wires
together. Look like a short read to happen to me.
Again thanks for the confirmation terminal (A) gets Red and black wire
Thank you Mr. T Man
Wow that's great. A succcess story.:)
It would be of interests to readers if you could do a short You tube clip.
I have never seen one operate.
1 - 10 of 10 Posts
