Never had one and never used one. Watched some stuff but everyone's application is different. Mine is not complex.
I am starting a Lionel Legacy engine with cw-80 transformer on Fastrack. I'm aware after a certain number of connections & distance (not so much) and load the need for drops will vary. Aside from just using the train to tell me where and when more power is needed by slowing now or I assume lights not consistent. How would I use a meter?
I certainly can see how continuity works and that's simple. Not sure if I need to worry about amps as I'm doing a floor layout, no accessories (for now), no switches, just a 2-8-0 Consolidation, and then several passenger cars.
Is it just drops in the voltage then which would cause my problems as I get further from source past more and more connections. Can you just put probes on the Fastrack( if so which 2 would I use) at various places and see if it maintains 18v? I think that's going to be at full power of a Lionel cw-80.
If it's relevant I am "not" looking to run the train at full speeds, and, my transformer/10" terminal track will be on a series of 30" straights.
Thanks for any info on how a multimeter might help me .
Cheers all
Cheers all
