Thanks. Which are the appropriate wheels to check btw?you can
- measure transformer voltage at various settings without it connected to track
- check for a track short by measuring the resistance across the track connections
- measure track voltage at various settings with transforrner connected to track
- measure the resistance of the locomotive (across appropriate wheels). should not be ~0
- measure track voltage at various settings with engine on track, prepared to stop if track voltage is substantially (??) lower than expected or if engine doesn't appear to start running
