1 - 5 of 5 Posts
To all,
Good day, never had a train set growing up, how sad is that. A friend from church gave me a post war set his dad had so I cleaned lubricated and put new cord on it.
engine runs great. My question to anyone out there is this.
The whistle blows ok BUT when I move the whistle stick to maximum throw the whistle just stops, as though I turned it off.
If I move the stick back a little bit it works fine. Is there anything I can do to fix this?
Motor vehicle Font Auto part Bumper Gas
Motor vehicle Automotive lighting Finger Gas Bicycle part
Are you testing it with the locomotive and tender on the track, or just bench testing the tender only sitting there. I believe the circuit is dependent on having a load pulling on it in order to stay latched and might not work properly with just the tender alone. Have you replaced the rectifier disc with a diode yet? I am actually in the same process with my 1033. There are actually a couple of active threads in this section right now about this very subject.
Diabolik,
Holy Mackerel, it works!
I put both the engine and tender on the test track and right away, IT WORKS GREAT!
Thank you so much for your help.:)(y)🚦
You're welcome. Only passing along what I have learned in my brief stint here from some very helpful folks. I wish mine were so easy. Mine didn't work at all, I did the diode upgrade and it worked great for about 30 minutes and the diode exploded. 😁 I am glad yours is working!
1 - 5 of 5 Posts
