BUT, I'm still having some issues
Yeah, I know, Pics!
Here's the problem. After finally getting the thrust washer & washer, I decided to forgo trying to wire the horn untill I knew that I was heading in the right direction. I greased her up, lubed her and set her on the tracks. I'm using a 1033, 90W transformer that puts out great #'s. All she wanted to do, was click, click, click. The headlamp was on, and I had the shell off. I could see the e-coil raising and lowering and the blunger rotating the drum. I gave her a gentle push forward, nothing. I started trying to use the directional control going back and forth. Finally there was some movement. It was less than an inch either way, with a stop in between(Neutral works?)
Finally she took off in reverse and flew!!! But when I try to go forward, she runs about a 12-18" then stops and just sits. Get her back to reverse, and off she goes, FAST!! Forward, 12-18", stop.
There's no smoke, nothing's burning up or glowing red hot. Do you think that this is a problem with my E-unit?
Thanks in advance for all your help, AND some darn fine instructional material
Jimmy
Yeah, I know, Pics!
Jimmy
