Wow, three weeks since the last update. Too many other things getting in the way, plus I've been working with the DCC++ESP32 code to try and clear up some bugs.
Meanwhile, I finally finished gluing down the printouts on the first half of the shelf last night. I'm ready to start laying down some roadbed for the mainline and transitioning down to the base level for the sidings.
A quick detail here... The foamboard comes in lengths of 30" so I needed 2.5 pieces to create my full 6ft length. I used masking tape on the back side to attach the pieces of foamboard to each other, and on the front side I adjusted my printouts to glue a sheet across each joint. This holds them together well enough for working on.
The next step is drilling the holes for the T-nuts so that I can maintain the alignment between the foamboard and the pink foam. I'm going to use 1-2 additional layers of foamboard to build up some areas, and I'm thinking about using foamboard to create my roadbed since both the cork and foam roadbed I have are quite a bit wider than the track and I don't have a lot of free space to play with on this shelf.
