1 - 20 of 63 Posts
I'm new to this, so forgive any ignorance. I'm trying to plan this ahead so I about mistakes or disappointment. Here is my basic plan. I need to try and get this into one of the design planning programs, they are just kind of awkward I'm my opinion, so it seemed easier to start with this. And using the programs to do a flex track curve is almost impossible. I'm aiming for a double oval with a tunnel on one end for one track. Flex track for the large oval bends and r18 for the inner track. I'm hoping for a max table width of 42", 40" would be even better.
All that said, what is the minimum distance between rails (HO)?
If you do 18" radius curves on the inner loop, that will put the center-line of the inner loop from one side of the table to the other at 36". Note that this is the center-line. Outside to outside will be closer to 38-1/2". Give yourself 2" track spacing, so now you're looking at 42-1/2" outer edge to outer edge from one side of the table to the other. You should really have at least 1-1/2" between the table edge and the track, and even then you will need some type of barrier 2-3" higher than the table edge all along each side to keep the train from taking the death plunge to the floor. 1/8" hardboard would suffice. So with two tracks as you propose the minimum table width I would go for would be 45-3/4". Spare another 2-1/4" and you have a 48" wide table, the width of a standard sheet of plywood. So in all practicality, trying to run two tracks with the inner on 18" radius on a 40-42" wide table really isn't going to work. Is there any way at all you can go 48"? If reaching across the table is an issue, put the layout on casters so you can pull it away from the wall when needed. Once the layout is built and wired, you probably won't be needing to get to the back side as often as you think you will.
Other than that you have a nice start to your layout.
Kind of afraid of that. There really isn't a way to make it movable where I'm putting it. The ledge as is is about 35 inches. The plan is to use plywood to lay over it and extend it out to the desired width. Reach is a concern, although it may be doable. It's low to the ground, so that helps. And with the center open you could please on that it even crawl in there (or have my son do it). I'm concerned 48" will stick out to far into the room though.
I suggest laying it out with the 15" radius and see if your train will negotiate it. Just don't make it permanent.
Then you will know for sure, in your own experience.
What radius was that circular loop in the pic you posted?
Get rid of the "s" in the upper right. Make it a "slightly angled" section of track instead.
Not sure what the two "spurs" on left and right at bottom are for.
Better to put a small "yard" in the middle of the plan.
Maybe an industry or two opposite the yard "on the other side".
Keep the minimum radius on the inside to 18" (or more).
Perhaps 22" radius for the outer track.
Make sure you have a way to access "the far side" of the railroad when necessary.
Bachmann recommends 18" but... only one way to know for sure. And it's free (assuming you have flex track) :rolleyes:
I'm not trying to spark a flame war, but you have a specific set of guidelines to which you need to adhere, and you may not be going for the more realistic appearance of the larger radius. If they'll stay on the track, your boy will be happy!
Heck, he might like it if they wreck, too!! (I didn't say that)
A couple of thoughts here. First, on layout software. If this is how simple your layout is going to be, then save your money and don't bother with the software. If you're going to go a little more complex, thennit's probably worth your time and money to get one. My personal preference is Anyrail, but keep in mind that these are all CAD (computer aided design) programs, and you're not going to just install it and start cranking out layout plans. There is a learning curve, especially for people not already familiar with some of the basic concepts.
Something you might consider, since you essentially have an oval with a lot of dead space in the center, is squeeze the two sides together, making a longer layout with two larger blobs at each end for the loops to turn the trains around. This may help solve some reach and space issues.
  • Like
Reactions: cid
Actually, I think you nailed it. O got so caught up in the information that says about 15" turns I didn't even think to try it. We aren't after realistic looking railways right now. If my son really gets into it and wants to do that later we can go that route with some more drastic modifications to the room.
I also like the idea of squeezing the sides in so they are closer. Good call
vette-kid;
There is a way to make your layout somewhat "moveable." You could mount heavy-duty drawer slides between the shelf, and your extension board. Then the entire layout could be rolled out to get access to the back. You could also get the 48" width you need, and still get the layout out of the way when it wasn't being run. Add a hinged board to give you the extra width. It could be folded up for storage. Also consider curved ends on the portion of your board that projects into the room. Curves are a lot kinder than sharp corners, when you ram them with your shins! A 1 x 3 plank, with padding on the outside edge would be even better.
Traction Fan
Discussion Starter #13
With just the F7A and B unit, my train seems to do fine on the r15 for a full 360. That's about as much as I can test right now until I get more cars. But I think it will work. The cars might be lighter, so I might need some weight to help keep them down but it looks promising.
I do think I will put the full 48" width up there to start and see how it goes. I can to it down later if we need to, but if it works ok, I'll have more room for expansion.
may have already been said but maybe somewhere to allow for the reverse direction. or maybe its there and just not jumping out at me. i have the same kind of thing where it's easy to do a couple of ovals and then have a entry/exit point -- but crossing it or providing a reserve gets a bit more tricky due to space issues -- which i've also had. maybe someone smart here can suggest some ideas if they agree.
basically "playability" ...
Discussion Starter #15
I'll have to think on that one, not sure I'm seeing the need. But there's probably a lot I won't get until I get some experience with it.
Discussion Starter #16
Some good progress and evolution of what was a loose plan. I’m sure it could be better with a better thought out plan, but I also have a 6 yo that is VERY involved in the process and he is making some of the decisions. I’m incredibly proud of how he is handling it, very diligent with taking care of the trains and he is having a blast doing it!
Some questions coming up. He REALLY wants a tunnel...so do I. I’m afraid that is really going to be challenging. There is room of course. The back right corner would be perfect. But actually making a tunnel/mountain seems daunting. It seems there is no real easy button here if you want it to look like a mountain or any type of f scenery.
With all that said, how are the woodland scenic kits? That seems the easiest route, nut I don’t know what I’m doing at all? Is it a plaster kit? Something else? I just want enough mountain to run the two tracks through the corner, maybe 3-4ft of tunnel. A simple valley that is high enough to hide he train would be the second choice.
What are my options? It doesn’t have to be perfect. Remember this is also a play area for a 6yo (soon to be 7). Here is a picture of where we are now. Buildings will come next, but slowly;along with more roadway.
Sent from my iPad using Tapatalk
Discussion Starter #17
Last pic is proposed location of the tunnel/mountain as depicted by my son's drawing!
My suggestion for building the mountain and tunnel through it is to build it using extruded solid foam insulation material. You can buy it at most home improvement stores. Get the 2" thick stuff if you can. You can use basic hand saws to cut and shape it to the rough dimensions of your mountain. Start with the bottom layer which will have the tunnel through it leaving the track path open to form the side walls of the tunnel. Glue successive layers on top of each other. When you have sufficient layers to clear the height of the train, then your next layers can form the roof of the tunnel and continue building up the height of the mountain. Once the glue is dried, you can further shape the mountain with hand saws and a rasp. It will be a bit of a mess with shavings, so keep a vacuum near by to pick up the particles. Some people have had good success with carving rock facings directly into the foam while others put a finishing layer of plaster or drywall compound over the foam. You can then prime the mountain surface and color it, put any grass or trees on it, etc. The foam will make the mountain very light weight. You probably don't need to glue it down to your layout which will allow you to lift it off to clean the track or retrieve a derailed car or engine. Please keep us informed of your progress.
I agree with what Mark said: extruded foam insulation board. Once the shape is built, take it outside and let your son apply plaster cloth over it. That's a messy job, and if he's a typical boy he'll LOVE it! Plaster cloth is made by a number of manufacturers. It's basically gauze impregnated with plaster. Dip in water for a few seconds then put it on the mountain. Let the first layer dry, then give it another layer. Double the fun! Once the plaster cloth is dry, you can go over it with a layer of Sculptamold, or just paint it and call it done. Have fun with it!
Here you go, hide one of these guys in the trees on the mountain:
Discussion Starter #20
Thanks guys. Doesn't sound too bad. Would it be wise to use something as a form for the tunnel and lay the foam over it? Or just the foam? And what do you use to glue it? Mod podge? I'll be making a hobby lobby run tomorrow so I plan to pick up a few supplies. Looks like 1.25" is the thickest foam board I can get locally,I love in a warm climate.
1 - 20 of 63 Posts
