I am both a (currently) budgeted model railroader, and that I also enjoy classic HO-scale train stuff (especially from Life-Like, Atlas, Tyco and Bachmann.) So I thought that for my basement model train layout I can use a lot of that stuff, yet still continuously update it for the new millenium. So far, I have my trains running on Atlas Code-83 True-Track (I'm not going to bother with Bachmann's E-Z track or Life-Like's Power-Loc track for the layout anymore, and I'm staying away from any of those other companies' brass and steel track sections), which I think turns out to be the most realistic roadbed track I've ever seen. I have even upgraded a few of my engines to knuckle couplers, and plan to do so even more (I'll probably go with Kadees for most of my Life-Like engines and some rolling stock, and Life-Like Scenemaster knuckle couplers for other freight cars.) I also plan to get an MRC power pack to replace the existing Life-Like one that currently controls the trains, and I will also probably eventually upgrade to DCC (maybe even retrofit it into some of the older engines!)
Because I will keep continuously adding onto the layout, currently not many things are permanently attached, except for some pieces of lichen. Here is what it currently looks like...
A current overview. I currently have the tracks set up ala the track plan designed for the Tyco Track Layout Expander Set.
Life-Like modular stock pen. I plan to decorate a few of the cows and pics, and paint a few more of the included figures. Also note the train having a Life-Like bi-level auto carrier car.
Life-Like operating log dump accessory. This is one of THE classic "action" accessories included with train sets.
Life-Like operating railroad crossing accessory. I recently replaced the rusted old steel rails with new nickel-silver rails, and it really made a difference. I may eventually motorize the gate and/or actually make the lights flash in the future...
Apple orchard next to a used car lot.
Plasticville gas station and a Life-Like "Snap-Loc" train station building kit that came with the Freight Runner train set (the lead locomotive here is also from that set.) Note the Life-Like lighted yard tower in the background.
Tyco operating crossing signal accessory. The wind-up bell works fine, but I need to fix the connection for the flashing lights.
Freight cars parked at the stock pen.
More freight cars. I also installed fences around the Vollmer and Bachmann houses, due to them being next to tracks.
The train passes through the Life-Like Pikesville Junction station building kit.
The crossing signal here is a Life-Like scenic light-up. The lights do not flash, but merely stay on steady, and it doesn't only come on when the train passes.
There's an unpowered siding at the supply house for me to display any not-in-use engines. Life-Like recently started putting cowcatchers on their 0-4-0 steam locomotives that use tender cars.
Yep, there's even a KFC on my layout!
One of two rerailer sections I purchased for my layout (as Atlas True-Track doesn't use terminal rerailer sections; they keep them separate, but I use terminal joiners on my layout.)
Lone Union Pacific caboose sitting on the siding. I typically use it if I have a UP locomotive pulling the train.
I plan to install a playground behind the school.
I also do plan to fasten down the outer loop of track using track nails or something some time in the future, mostly just the curves, as I plan to probably install more switches and sidings in the forseeable future, as the Tyco Track Layout Expander manual describes (I purchased a copy of that as well for ideas), as in this track plan:
Until I upgrade to DCC, I could even try the old method of operating two trains using two power packs and some plastic insulating joiners.
