They are EASY to cut…. 😉A typical flat shoelace would make about a 12-18" hose in N scale! Or more!
Perhaps some pinstripe tape from an auto parts store... Maybe use Goo Gone to remove the adhesive.In other words - I need something really really thin. Perhaps some "heavy EZ-Line"???
I think pin striping would tend to curl wouldn't it? Have to admit, I am leaning toward the shoelace idea at the moment.Perhaps some pinstripe tape from an auto parts store... Maybe use Goo Gone to remove the adhesive.
True, even though I still might put in some "openings" down the height of the tower. Maybe let one hang half way down where the end could be seen - just for fun and a little guy up top trying to untangle it ??You might not need to show the ends….they will dangle down deep into the hose tower, and there are no windows to be able to see the ends…
You will once I cut the openings up the tower - or, I could put it on the outside as wellBut…..you won’t be able to see them….![]()
That's the plan Sir, that is the planIt would make more sense to put them on the inside then….
