A few weeks ago I found my fathers 1952 Lionel train set and it was not in the best condition. The engine was seized up and the tender didn't function. All of the insulation on every single wire was cracking and falling off. It has seen better days that is for sure. My father had a 180 watt transformer but the wires had been cut at some point and the handles are broken so I opted for a new transformer. I purchased a MTH Z-1000 as I had read good things about it.
I took the engine and tender to a local lionel repair center and they were able to repair it but it took 3 weeks. From what I understand they had to order some parts, rebuild the e-unit, and do a complete cleanup and lube. When I got it back last Sunday it was working great for several days but I did notice a lot of arching as it ran from the engine and the tender. Here's a video of how it was working
https://www.youtube.com/watch?v=PCiDmw-ch40
The night that I took that video it started requiring more juice to keep going and eventually just stopped. The train now doesn't seem to want to go into gear. It doesn't matter how I have the e-unit switch set it just will not run forward or reverse. I have tried cleaning the track and that did nothing. I have checked the lubrication and it all looks to be good accept for some of the gear box grease coming out one of the wheels. I also checked the voltage off the new Z-1000. I get 14v on the nose from the accessory ports and the variable 0 - 18.5 volts from the controller. This all looks correct to me. I have not yet checked the voltage on the track all the way around. I ran the caboose around it that has a light and there were no parts of the track where the light flickered so it looked good to me.
I have also tried minimizing the track down to just 3 links of straight brand new 0 gauge tube track. It still will not function. On top of all of that the tender has also stopped working. It clicks but the motor does not engage.
Today I went to a train show and found an old 90's costal limited set for under $100 which seemed like a good deal for all I was getting. Figured it would help me diagnose the issue and get a few more pieces to fill out the set.
It was complete but did look like it had been run. I figured I could use a lot of the pieces and have another nice looking engine and tender even though I can't use the track. Maybe I could do an inner loop or something.
I got the train home and tested it out on the track. It went 5 times around the track then came to a stop and made a horrible plastic burning smell. It too will not run on the track now. I pulled the new engine apart and checked the circuit board and nothing is burnt up. The motor still turns smoothly and everything seems nice and loose. I re-lubed all of the spots recommended in the manual with 3-in-1 oil. It looks like the plastic burning was coming from a wire going into the smoke unit as it looks like some melted plastic around there but nothing to bad. The train won't run though. I even tried it on the o-27 track it came with and the 40 watt transformer it came with. That thing is variable from 0.6-18 volts and seems to be working ok.
I'm completely at a loss here. I have now replaced almost all of the old 1950's track with brand new track from the train store, I'm using a lionel lockon for the connection. I guess it's possible both trains are having the same problem but it really seems like it's the track.
The train shop that fixed the berkshire told me to bring everything in and they will help figure out what is going on but they can't look at it until tuesday or wed. It's really getting to me so I'm hoping one of you might have an idea. I don't know what else to try.
