1 - 4 of 4 Posts
I just bought three new engines, two Model Power 0-4-0 Switchers one with a tender and the other one without, and a Bachmann Spectrum SD-45 DCC equipped.
How do you break in new engines? Do I have to do anything to the Bachmann engine to allow it to run on my DC track? I will b convertingto DCC in the future but want to run the engine now.
As long as your still DC just place the loco on the track and allow it to run slowly in one direction for about 10 minutes and then reverse the direction for about another 10 minutes and you should be fine. It still might sound a little noisy at first but not to worry it will be fine once it's been run some more.
If your running a DCC track and the loco is DC place it on the track and use the address of "0" and don't run it more than the 10 mins in each direction before you put a decoder in it. Also check for excessive heat inbetween the 10 minute intervals. DC loco aren't really meant to be run on a DCC track but won't hurt most in short intervals.
Hope I answered your question. If not or additional questions arise just post back to this thread and someone will assist
"Enjoy it's built rite in."
I was wondering what would cause the dc loco to get hot?
I've never had a problem running DC engines on a DCC track. Never noticed any extreme heat build-up. Regardless if the layout is DC or DCC, the voltage will remain the same. I will say the my old amp hog Athearns get warm, but they also pull more amps, the nature of the beast.
1 - 4 of 4 Posts
