1 - 17 of 17 Posts
We just got our new mth railking 2-8-2 Mikado... the dcs isn't here yet. I figured we'd fire it up in conventional mode and play around a little. I'm using a lionel 1033 (oldie but goody). I throw the juice to it and it fires up, smokes and yard sounds start playing but I cant get it to move. The manual states to give it 10-12v, back down then back up. I try this and nothing.
Also, the guy at the store I bought it from said that my tmcc will run it. I don't believe this to be true. Is this possible?
Thanks so much in advance!
Joe
Joe
I believe when you back down then go back up you can't do it quick, you got to do it slow.
I don't know about the TMCC.
I don't advise postwar transformers with modern electronics. As far as the whistle goes. The DC from the 1033 will operate a postwar relay but is not known to work with electronics needed to operate sounds. The electronics is so expensive I would not think of testing it.
It is made to work with a CW 80 that has a bell and whistle and probably better throttle control.
Thank you for the replies!
I don't intend to use this trans at all... I wanted to pacify the kids a little.
I'll give the slow up/down a try.
Thanks again.
With a Protosound 2.0 locomotive, the speed at which you turn it off and on does not matter... It only matters with a Protosound locomotive... PS 2.0 locomotives actually start in neutral, not a RESET stage...
Mth RailKing 30-1164-1 2-8-2 Mikado.
When you turn it off for that split second, do the sounds stop playing? Have you tried leaving it on the track for like an hour to temporarily charge the battery?
Discussion Starter · #10 ·
I called MTH and they said the battery's dead. They advise leaving it on the rails at 14V for three hours.... which I'm doing now. When the power's cut, the sound should stay on for 8-10 seconds with a full charge. At that point, lowering and raising the voltage will engage forward or reverse.
I check the battery with an ohm meter and it showed 9.4v - last night. I assumed it was charged but looks like it was just a surface change. I have no way of pulling a load.
Thanks again for all your help - everyone!!!
The one time we didn't say. CHARGE THE BATTERY!:(
He did say he had sounds??????
I hope he sticks around.
Discussion Starter · #14 ·
Did charging the battery work?
Yes/No. Yes, when I let it on the track to charge for 3 hours. No, the battery's shot - won't hold a charge. I would of thought the retailer would of either suggested a new battery or just installed a new one. It appears as though is was out on a shelf. :thumbsdown:
Discussion Starter · #17 · (Edited)
Radio Shack does sell rechargeable 9v batteries but you have to be careful though... you don't want to mix in a Nickel Metal and they do sell both NiMH and NiCd. It should be 8.4v 120mah NiCd.
I called the retailer and explained what was happening. After a good solid 5 minutes of the guy huffing and puffing he gave in and said they'd send a new one. Of course, they're out of stock now. lol. Our DCS came today so it's not really an issue now.
I just double checked R.S.'s website and they only show NiMH. Also, be careful with a standard Alkaline battery. I'm not too familiar with MTH and how the battery is charged yet but alkalines will over heat if they're attempted to be charged.
1 - 17 of 17 Posts
