1 - 20 of 43 Posts
Well I finally have a room where I can make a permanent layout. So I have come up with this, the only thing it needs is a sliding for the locos on the passenger line.
It's about 1.2m x 4.1m, if I could get it narrower that would also be good.
So any comments will be appriciated.
Cheers
Nice plan.The only concern I would have, besides the aforementioned gap, is the yard and stub sidings on the bottom of your picture.
If that side is against a wall you will have some reach issues, especially when the scenery is in place.
What scale?
I just noticed both the blue and the yellow
tracks have what appears to be a turnout
but no track is connected to them. These
are on either side of the benchwork 'cut out'
What are they?
Did you, perhaps, intend a double crossover?
What are they?
Actually, they look like two curved tracks overlapped each other. I believe that it was intended to be one track but not using the flexible track to connect them instead of two tracks overlapped.
Question: what would be part of the scenery? It seems to be all tracks and just single building? What about point to point bases for the passenger service?
Discussion Starter · #6 ·
Hi
Sorry I did not close off or trim the tracks, I was trying to get a feel for the layout.
Scale is HO, I'll have to measure the diagonal reach on that, the other thing I thought of was if the yellow line was for passenger service than the Radius Two might be too tight.
There will be walls on three sides, you walk in from the top. So maybe it's all wrong from an access point of view?
Cheers
Discussion Starter · #7 ·
Thinking about the access issue I came up with this (excuse the lack of trimming and joining).
The main thing I want to incorporate is to have two controllers (DC at this stage) on for each loop and the ablity to run shunting operations with both contollers.
The only thing is that the freight part will be in a valley surrounded by the passenger line, but then in iron mining your digging holes.
The inclines are steep (4%).
May I should bring the station to the front and drop the two main lines along the long wall and build over the top to reduce the width, but then the access will be an issue.
Hmmm, this is alot more complicated, I need a bigger room
Try it with the yellow all upper level, then you can put the grade on the longer blue line and let it connect to all the yards on the lower level. You can further reduce the grade by making the passenger station level (blue and yellow) the same half way elevation and as they leave the yellow goes up and the blue goes down so the yellow can go under the blue at the front. I think that would also allow you to squeeze in the middle and give you a little better access.
Discussion Starter · #10 ·
I've moved a few things round, the longest reach is about 1 metre.
I've dropped the split level with bridges over the instead I've opted for a port, since I have to off load the iron ore somewhere. That way I can still have a split level, get the grades at 3% without crossing any tracks. I have tried to keep the areas furtherest from the edge of the table free of points, thus less chances of derailments.
I have been thinking about how the operations would work. To come out of the port I would have to reverve back onto the main line, but then is it real a deal breaker.
May I suggest that you move the port to the passenger fiddle yard area,as well as the ore offloading track? That would give you an ore " complex" and a short switching lead as well. The port would be off the edge of your bench work.
Then add another ladder track to the former ore offloading track to accommodate the passenger yard.
Just a thought :)
Discussion Starter · #12 ·
Hi
I have nailed down my layout, now I have need for clarification regarding the control of my layout. Initially I thought of using one power supply and creating three simple controllers using a potentiometers and a step down component to run the inner, outer loops and sidings. Upon further searching I found I can create blocks where I can wire it up to allow the use of just two controllers and the use of DPDT switches to swap between the controllers.
So if I have this right, in theory I can use one controller for the outer loop swap over to the inner loop just by switching that particular block to that controller, rather than swaping between controllers.
However, how would I isolate parts of the layout using that method.
Or would it be better to to run the outer and sidings with two controllers and set the inner loop to a constant speed and have a train just run around it, since the outer loop and sidings would require more driver input for operations
Just to add I was going to run the inner and outer loops in opposite directions.
Cheers
Is it too late for you to reconsider using DC? Since you
plan to run more than one train at a time you would
be doing yourself a favor by using a DCC system.
You then would not need any blocks or insulated
joiners. You would not need several DPDT switches
and yards of wiring. You would not need two or
more controllers.
You could have crossovers connecting all of your
tracks and have only one controller and a single
two wire buss to power all of your track drops.
And you would have easy individual control of
each locomotive on your tracks. One DCC controller
can run any number of trains at the same time
each at it's own speed and direction.
Discussion Starter · #14 ·
Hi
I have only put the track down and not started the wiring. At this stage DCC seems like the logical choice, it's just the expence of changing over. By the time I chip all the locos (if they can be chipped) and two controllers I don't think I would get much change for a $1000.
I'll have to do some more reaseach on it. The first criteria would have to be that at least two people can run seperate trains on the layout and or loop if that's possible.
What would be a middle of the range DCC system or brand (loaded question)
Cheers
You should be able to go DCC for much less than
1,000.00.
http://www.modeltrainstuff.com/NCE-...e-524025.htm?gclid=CM-m3MGGnNACFdgNgQod7xUJuw
There are other systems for much less.
Decoders run less than 20.00 each.
You don't need to convert all locos at the
same time.
Use a DPDT switch in your main track buss. One
way it's DCC, the other way it's DC. You can run
both systems, but not at the same time. You would
want to keep your DC only locos on a track that is
capable of being turned off when using DCC.
The advantages of DCC far out pace the cost
factor.
1,000.00.
same time.
factor.
Thats what I did!
Although i picked the digitrax system instead of NCE.
From what I have heard the NCE system is much easier to deal with.
Super glad I put in the switch for changing a loop of track to dc OR dcc. I still have like 15-10 DC loco's. now i feel like i don't need to change them.
Thats what I did!
I would recommend that you change them over gradually. Having to change out locos, isolate parking areas, or just not being able to run the loco you want to in conjunction with another will get old.
Discussion Starter · #19 ·
Sounds like the way forward, I was looking at getting two controllers and a power booster. I guess I just need to get my head around wiring it all up. So you can run DC from the DCC controller?
Back to the researching :)
Some DCC controllers claim to have capability to
run a DC locomotive. However, many of us would
not do that. DCC track is continually powered with
14 volts or so of modified AC. This current can
damage a loco motor if left standing.
The better way is the simple DPDT switch that
sends either DCC from your controller or DC
from a power pack to your track buss. However,
the reverse loop controllers would not work on
DC, and they could possibly be damaged.
1 - 20 of 43 Posts
