Sent from my SM-G960U using Tapatalk
Some of you have seen the new layout I have started, so I'm going to start my own thread here. Started doing some wiring on the frame of the central part of the layout this evening. I am using ground busses to run 12 gauge wire from the TIU unit to various points of the layout. I will then use smaller drop leads from the track to feed off of the busses. I am planning on having the two variable voltage channels of the TIU to run the main level. One channel will be used for the continuous main line, the other to run a "working line" where my kids and I can move cars around and put them out onto the main. I also plan to have various sidings the can be turned on and off from toggle switches along the main line. I have a mix of conventional, Lion chiefs, TMCC, and MTH dcs units that will be used on the layout. The plan is to have them all sitting on the layout most of the time. My main source of power will be an older ZW transformer which I have 10 amp fuses between the transformer and the input of the TIU. Maybe some of you guys can answer this for me. If I am using the same transformer through all channels of the TIU, can all of the track leads go to the same ground bus? Or should they have their own ground?![]()
Scroll up a few posts and watch the video. More may come, but that's what I have for now.Clark Kent is from Smallville. Are you going to have his alter identity on your layout?
I had block glass installed in my basement windows too. Lets a lot of light in, but no one can see in.One window replaced. One more and I can complete the platform.![]()
Sure, but you can't see out either.I had block glass installed in my basement windows too. Lets a lot of light in, but no one can see in.
That's okay, I can see out upstairs.Sure, but you can't see out either.![]()
MTHWhat portals are you using? Hard to tell from the pic.
