1 - 20 of 37 Posts
Hello All.
I'm a scale modeler mostly 1/48 scale A/C..but have dabbled in trains over
the years.. I recently purchased a Lionel train. I bought the set North Pole
Central Christmas train set. It worked fine for 3 days!:laugh: What the train
is doing when it does work is reverse only, and half the time nothing at all...
I can wiggle the locomotive on the track and I get some sparks then it starts
in reverse...if i try to switch direction it stops working then I have to play
with it again to make it work...reverse only..
I contacted the place of purchase and they suggested i call Lionel, Well I
called tech support and was told my call would be answered in 22 minuets,
well i don't have time to wait 22 minuets while at work!!! and by time i get
off tech support is closed.
I dont know what info you guys may need about the train....Here is some
info, if you need more just ask.
The number on the Locomotive is 1679EL1(on bottom of train)also says 4-4-2
The track is a fast track system.
PowerMax Plus Transformer (has a direction control button, whistle control
button, bell button and the throttle handle)
I know things break over time but I hate to think after only 3 days use I'm
already having problems. Is this common with Lionel trains? And the fact that
the Hobbie shop i bought it from really didn't care, kinda like Your problem
now buddy!:laugh:
Ok I guess that is enough for now! Thanks for any Help.
How about placing a jumper over the switch. You want it on.
You do have an electronic e unit right?
If you flip the engine around, Does it still reverse?
"I know things break over time but I hate to think after only 3 days use I'm
now buddy"
That's why I have more than one engine. I owned a 2333 for 25 years before I fixed it. Another option is to run it on DC.
Is this the set?
Also where is the whistle is it electonic or mechanical?
Is the reverse board in the engine?
You have two switches one for reverse boar the other is smoke. Turn the smoke off when not using it. It like Keeping a stone top on for nothing.
Sometimes an engine will have a wire that is protected from hitting the frame with some tape.
Check to make sure that none are touching the frame. As this will cause running problems.
I don't know much about the electronic boards.
Also, clean your track (electical power off!!) and the electric pickups on your engine with some mild soap; use a Q-tip on the engine's pickups and a dampened paper towel to wipe down the metal rail surfaces. It's possible you're getting weak or interrupted current with some non-conductive surfaces. That can give you two interlaced problems, one with getting consistent current and the other with a short, switch, etc.
Discussion Starter · #7 ·
quick reply while at work
Yes t-man that is the set
whistle sounds mechanical
im not sure where the reverse borad is..looks like it is in the train.
I have fliped the engine around and only reverse
I have swaped power leads (red on black and black on red) still only reverse.
I have tested the amps with a meter. i have good power in both directions.
Wrap a piece of copper around the back end of the switch. Then on /off an even amount of times before trying. The switches aren't the best.
You nay have to look at that boared to see if something got fried.One member did change a transistor a little black cylinder the boars has two of them.
Discussion Starter · #9 ·
Thanks for the help every one, I really appreciate it.
T-Man, I really don't want to mess with the train to much..it being only 4 days now since I've got it out of the package, but trying to get customer service or even tech support is a no go right now.....on hold 30+ minutes or they are to busy call back later....
The only reason I'm hesitant about going on the insides of the train is if I have to send it back for warranty or try to exchange it..but this may be my only option.
once again thanks for the help!
This is the board.
DO you have the engine number?
It would be best to find the supplement for it first.
Normally there is a screw on top or in the cab. Then you undo screws in the underside of the steam chest. A rail on each side of the boiler disconnects the rails.Then you have to undo the tender bar and pull the motor out
Discussion Starter · #12 ·
Alright I got the train apart. pulled the little unit out...looked like a nuclear meltdown!:laugh: yeah it looked bad. got on Lionel website found my train and ordered 2 E-units...
Thanks for the help guys! I hope a very happy New Year to all of you!
Now i just sit and wait!
WOW this is a hot thread! 154 views.
Do you want to run the train?
Supp 21 (page 12 by the bookmark is a typical diagram. I
WIth four wires you run the engine. Connected to a brifge rectifier, Radio Shack 276-1146 about 2 bucks
Black and red from the motor.
Brown ground outside rail
black center rail
You also have a black smoke optional. Cut the wires at the board. Use elctrical tape when you are done soldering the connections. I am not sure if it will go forward. If not then reverse the motor wires.
Shown are two rectifiers that will work. They will give you practice before you installl a board.
Any chance of sending me the bad board?
If the big IC on the old unit ,in the center is cooked, your done. The chip is programmed so an off the shelf won't work. I looked into making one and that is what I found out.
Working older engines I found out always to give it a try and learn. What is there to lose except some cash for parts.
I am surprised it failed. My only engine doesn't have a lot of run time but I always thought the e unit was reliable.
Anyway, another 150 and you can get another wholeset!:)
Discussion Starter · #18 ·
ah..ok lol had me worried.
Once again thanks for your help.
I really don't know why it failed, i was running the train at a slow speed setting, all was fine walked away and it had stopped. Maybe I had it running to slow...i dunno.
I have the same exact engine however, the engine does not move at all and it is 2 years old. I see on Lionel's website there are two E-Unit boards that look different. Do I need to purchase both or are they just two different types? If I only need one which one do I need to buy?
Thanks
Jay
1 - 20 of 37 Posts
